Discussion | Topaz & Scanned Images
Hi
Before I buy Topaz AI, I have a question that somebody may be able to help me with.
I have a few out-of-copyright colour illustrations in old books.
The scanned images are poor when enlarged.
I think Topaz could be used to improve the resolution, allowing for a better-quality enlarged print.
Any comments?
Thank you
Either Topaz Gigapixel or PhotoAI might help. It all depends on the image. Topaz products can be downloaded and tried before you purchase. That might be the way to go.
I’m curious, when you scan, what are the dimensions and resolution? Perhaps you just need to scan at a higher resolution. Unless of course the images are very small.
The scanner is fairly good; the image is not pixilated by the scanner but shows the print defects.
I have 2 things in mind: 1) scanning a book of black and white prints of geometric patterns
2) scans from books with colour illustrations, line drawings from old engineering catalogues
As @Mike.M has asked, what resolution are you scanning at?
Hello Peter
If you can post a picture of one of your scans we might be able to see if you have used the correct scanner settings. It’s important to get the right settings.
Regards Bob.
