Is there a tip for protecting and area to avoid modifications durnig “Dust and scratch”.
Le process eliminate some details I want to keep.
(for example : flowers in the hand of a little girl : the process erase the flowers and put instead a piece of her sweater)
AND-E
Hi Michel.
I had a similar issue with an Old Photograph the Subject was wearing Lace and the Dust & Scratch Filter had smudge the Lace
The trick is to Apply Super Focus first to increase the details then Apply the Dust & Scratch Filter
Here’s some information about using the Dust & Scratch Filter and Best Practices
In addition, would it be possible to post a Before and After examples
Hope this helps
