DenoiseAI has limitations in batch capabilities.
The application seems to try to read pictures (or other actions) while loading them. In my opinion, this is wrong.
You sound like your trying to process video frames, probably PNG, try Video Enhance AI it has its own noise reduction.
AiDon : Your comment is not about the issue of loading X number of images. Please focus on the issue and do not hijack the thread.
I wasn’t highjacking the thread, I offered a suggestion for you to try.
Fine. It was a good suggestion.
resolved
Problem solved.
