To reproduce, open a CR3 (Canon compressed raw file)
crop the image
rotate the image
add a sharpen (subject) / denoise (background) filter
show the mask (see attached screenshot) … the mask is correct but has not been rotated?!?
crop the image
rotate the image
Thanks for flagging.
We relayed this to the development team. We can circle back here if a fix is found. As a workaround you can crop later in your workflow as it would avoid this issue (in Lightroom for example)
