DeNoise AI v2 seems to work fine as a plug-in on a smart object until I reopen the filter and the changes I made are not there anymore. This is annoying and I don’t see anyway to make a preset so I can quickly reset my adjustments until this is fixed.
Switched to a feature request as DeNoise doesn’t support smart objects.
You and others that want this feature can vote here. Click the vote box.
Thanks. I use all my Topaz products as plug-ins except Gigapixel and jpeg to raw.
Great work guys. Thank you for this product! It helps me a lot.
It would be really nice to have this feature as I’m always using a non destructive workflow on my images.
I hope there will be more votes on this.
