Updated to the new version 1.2 today. Had a play, and just noticed that if I set it to the ‘Clear’ option, and then exit the program and come back later, restart the program the setting has reverted to ‘Denoise’.
OK, so it’s a Denoise program with a Clear option, but it would be nice if it retained the setting a user has chosen when it next restarts.
Maybe the older version did this too? I didn’t check as I was not happy with the older version so didn’t use it much.
Is this ‘forgetting’ of the option normal? Was it designed this way?
Or, am I doing something wrong?
Thanks.
Changed it to a product feature request for you.
+1. Since you can’t create presets it should at least remember the last thing it did.
