I don’t know if this a bug or just a missing feature:
I use DeNoise AI 2.1.6 as a plugin with Photoshop 21.1.2. My usual workflow is to select the background layer, convert for smart filters, and then apply DeNoise AI as a smart filter. The advantage of smart filters is that they can be re-adjusted at any time. However, when I re-open a DeNoise filter that’s already been applied, it returns to the default settings, rather than keeping the settings I had previously used. Is there a way to make it remember those previous settings? It’s very frustrating when I just want to make a small adjustment but instead I have to completely start over. Thanks.
