Application & Version: Topaz DeNoise AI Version 2.2.11
Graphics Hardware: GeForce RTX 2080 Ti/PCIe/SSE2
OpenGL Driver: 3.3.0 NVIDIA 451.77 (on this version because the latest one is very unstable)
CPU RAM: 65236 MB
Video RAM: 11264 MB
Preview Limit: 7895 Pixels
I used the auto and low light mode at first and although it didn’t show up in my preview it rendered out this was once i said Apply.
I have had this happen on more then one occasion when using Denoise on B&W photo’s mostly but have seen it on others. The image was RGB 16bit. I’ve re-installed GPU drivers even though i haven’t had issues with other sensitive apps like Adobe. Yes you heard me right I am on a driver that is one release old but using the latest driver 452.06 makes Premier and other Adobe products i work with just not stable enough. So unless there was a specific fix for this in the latest GPU drivers i don’t think it should matter.
Regardless i’m open for ideas or at the very least what could cause this? Thanks. Picture attached.
