When saving a custom preset, it either saves the Enhancement details (Proteus), or the Stabilization and Denoise details, but not both.
I.e., if I save a preset with the Enhancement switched on, none of the other details are applied when I apply the preset. If I have the Stabilization and Denoise switched on, and Enhancement switched off, only then do the Stabilization and Denoise apply when I apply the preset to a new video.
I think I know what the problem is too. Proteus allows you to adjust the other settings, but Starlight Precise 2.5 greys them out. What must happen is that when applying the preset, first Enhancement is applied with default settings (Starlight Precise), and then switched to Proteus. However, the Starlight Precise setting overrides the other settings and removes the Denoise and Stabilization which were saved in the preset.
I’ve tried to find a way to remove Starlight precise or make Proteus the default, but have been unsuccessful. Is there any way to fix this? Thanks
