I can crop, but when Gigapixel AI renders the preview is back to the full image. Cannot save cropped either, only the full image. I will be uninstalling this broken update ASAP and going back to 7.0.2 (I knew I saved old versions for a reason). Will check back some day down the road to see if you have addressed this as 7.0.2 works fine for me.
Sounds like odd behavior that you’re experiencing. Could you reach out to Support so we can dive into this conflict a bit more?
