How do I do composite inside Topaz Studio 2. I want to be able to mix two different shoots as one.
Thanks
Thanks
Please choose the correct category when you post in future … Topaz in the News is not relevant to your question.
At the present time the only way is to use the Textures filter as the Image Layer is not yet implemented. Open the Texture Category Manager and import the image to mix with the existing image you are working on:
Then use import texture to import into a category of your choosing:
