I have a lot of video in various older formats that I want to upscale, and would like to understand if replacing my machine or getting an external GPU would significantly improve performance with VEAI. Below you’ll find information on the machine I’m using and the seconds-per-frame required to upscale different types of source material to varying sizes. If you’re willing, please run similar tests and post your results here along with details on your hardware config.
The specs of the setup I’m using (Apple iMac, Retina 5k, 27-inch, 2019):
- CPU: 3.6 GHz 8-core Intel Core i9
- System memory: 64 GB
- GPU: Radeon Pro 580x 8 GB
- OS: MacOS 12.6
- Topaz VEAI version: 2.6.3, with “Max AI Processor Memory Usage” at the highest setting.
The results:
| Dione Interlaced Dehalo | Artemis Dehalo | Artemis High Quality |
Source | 720p upscale | 1080p upscale | 4k upscale | 1080p upscale | 4k upscale | 1080p upscale | 4k upscale |
SD (MiniDV and | 0.16 sec/frame | 0.16 sec/frame | 0.43 sec/frame | | | | |
Analog->DV | | | | | | | |
passthru. | | | | | | | |
conversion) | | | | | | | |
720p | | | | 0.41 sec/frame | 1.06 sec/frame | 0.41 sec/frame | 1.06 sec/frame |
1080p | | | | | | | 0.89 sec/frame |
As a Mac user, I’m wondering if getting one of the M1/M2 Macs would be an improvement over what I’ve got. Alternatives would be to purchase and external GPU enclosure and a faster/better GPU card, or if it makes more sense price-wise purchase a PC with good specs to dedicate to running VEAI.
Thanks in advance to anyone willing to run similar scenarios on their machine(s) and post the results.
