Community Forum Theme Options Removed?
Loaded into the forums a few minutes ago, and was greeted by a flashbang of white from the light forum theme. Usually I have the dark theme selected, so I went to my site preferences only to find there is no theme options anymore.
Is anyone else experiencing this? Have the options been moved somewhere else? Am I destined to be blinded whenever I load into the forum, now and forever?
The same happened to me I just set it back to dark mode. It’s in the settings under interface.
Thanks for pointing me in the right direction. They seem to have added new options, which I don’t recall seeing before.
I don’t see any “Settings” available for the website???
Click on your avatar in the top right, then the silhouette icon at the bottom of the list of icons down the right-hand of your screen, then preferences.
On that screen one of the tabs (you may need to scroll right) is called interface. I’m doing this on mobile and it may look a little different on a bigger screen.
You can try this link too: https://community.topazlabs.com/u/andymagee-52287/preferences/interface
Thanks for that!
I would never have found my way that many layers deep without a guide. Even then it showed me already set on dark theme, but the screen background was blazing white. Had to monkey with the color settings to get things properly back to what they were.
p.s.
I wonder if they realize that this indirectly provides market size information? Topaz Community
I’m sure they’re aware, but I think that only includes people who have actually logged into the forums so it’s only a lower bound.
