This Artemis only works fine:
"c:\Program Files\Topaz Labs LLC\Topaz Video AI\ffmpeg" "-hide_banner" "-nostdin" "-y" "-i" %~f1 "-vsync" "0" "-avoid_negative_ts" "1" "-sws_flags" "spline+accurate_rnd+full_chroma_int" "-color_trc" "1" "-colorspace" "1" "-color_primaries" "1" "-filter_complex" "veai_up=model=amq-13:scale=0:w=3840:h=2160:device=0:vram=0.9:instances=1,scale=w=3840:h=2160:flags=lanczos:threads=0,scale=out_color_matrix=bt709" "-c:v" "prores_ks" "-profile:v" "1" "-vendor" "apl0" "-bits_per_mb" "8000" "-pix_fmt" "yuv422p10le" "-map_metadata" "0" "-movflags" "frag_keyframe+empty_moov+delay_moov+use_metadata_tags+write_colr " "-map_metadata:s:v" "0:s:v" "-map_metadata:s:a" "0:s:a" "-c:a" "copy" "-metadata" "videoai=Enhanced using amq-13. Changed resolution to 3840x2160" C:\video_processing\TVAI_export\%~n1.mov
This Chronos + Artemis fails with error:
"c:\Program Files\Topaz Labs LLC\Topaz Video AI\ffmpeg" "-hide_banner" "-nostdin" "-y" "-i" %~f1 "-vsync" "0" "-avoid_negative_ts" "1" "-sws_flags" "spline+accurate_rnd+full_chroma_int" "-color_trc" "1" "-colorspace" "1" "-color_primaries" "1" "-filter_complex" "veai_fi=model=chr-2:slowmo=1:fps=48:device=0:vram=0.9:instances=1,veai_up=model=amq-13:scale=0:w=3840:h=2160:device=0:vram=0.9:instances=1,scale=w=3840:h=2160:flags=lanczos:threads=0,scale=out_color_matrix=bt709" "-c:v" "prores_ks" "-profile:v" "1" "-vendor" "apl0" "-bits_per_mb" "8000" "-pix_fmt" "yuv422p10le" "-map_metadata" "0" "-movflags" "frag_keyframe+empty_moov+delay_moov+use_metadata_tags+write_colr " "-map_metadata:s:v" "0:s:v" "-map_metadata:s:a" "0:s:a" "-c:a" "copy" "-metadata" "videoai=Slowmo 100% and framerate changed to 48 using chr-2. Enhanced using amq-13. Changed resolution to 3840x2160" C:\video_processing\TVAI_export\%~n1.mov
[veai_fi @ 0000028220CCA640] Unable to parse option value "0" as video rate
Filter scale:default has an unconnected output
Any clues on why it’s failing? I don’t even see a switch for video rate. These were copied from the GUI FFMPEG command dialog box, and it runs in the GUI (though crashed after several hours). The CLI seems the only stable method of using TEVAI.
