Can't turn off face recovery regardless of settings
GigaPixel 8.2.0 on an iMac 2020 (Intel) running MacOS 15.3.1 (but this has been going on for a while).
I’ve turned off Face Recovery in the upscale settings palette, and in the prefs for Face Recovery I have None Selected.
I do mostly b&w lineart, but regardless of which model I use (auto or manual settings), it goes through the cycle of trying to detect faces to recover. It can be a frustrating slowdown when you’re trying to move quickly through images and you want to switch between settings.
Any ideas?
Thanks -
Scott
HI Scott,
We are aware of this bug and working to investigate and fix this issue.
Thank you for letting us know.
If you need, you can submit a ticket with our Support team and we can communicate with you more directly for updates.
We appreciate your patience!
Appreciate the reply. Good to know you’re working on it. Will await the imminent fix.
Has this been resolved yet? I am having the same problem after I installed updates.
Hi Cindy!
This should be resolved with 8.3.3 - please update to this version and let me know if you’re still having issues. You can submit a ticket with our Support team and we can communicate with you more directly to help troubleshoot.
