I’m trying to post to the Bugs and Issues section. It tells me I need to select at least one tag but no matter what I type into that box all I get is “No Matches Found.” Is there a secret word that I don’t know about?
Thank you.
Thank you.
No, just click in the tag field and select the one you want.
You should be able to post now.
It was an issue on our end where only admins/employees could use tags, but at least 1 was required. This is now fixed.
Thanks, Eric!
