Hello,
my system-harddrice C:\ is running out of space.
That’s why I have installed Topaz Mask AI on another drive (D:)
But the setup still creates on C:\ the following folder:
C:\username\AppData\local\Topaz Labs\Topaz Mask AI\tgrc
This folder uses more than 1 GB discspace. But I need this space I urgently free.
My question is: can this folder be located on a different harddrice than C:?
And if so, how could it be moved from C:\ to another drive?
Thanks for helping me with this.
I am not sure about your size of the LocalAppData folder as mine is only 1.82MB,
The “tgrc” is automatically installed in the “DiskId:\ProgramData\Topaz Labs LLC\Topaz Mask AI” folder that is created on install and you can select the folder yourself. For example, in my case, I install Program Files and Program Data on the D:\ drive.
Your LocalAppData folder should have this structure:
So anything else there can be deleted as it isn’t part of the current install which is v.1.3.5
Thank you very much for your help!
