Can a Radeon 780M work (crashing)?
I picked up a Ryzen 8745HS with Radeon 780M. Just want to do some light processing. 1080P cleanup with with Artemis or Iris. Crashes at the initiation of the processing. Is the 780M absolutely not able to work with the program?
You’ll need at least 6GB of VRAM with a dedicated AMD GPU, you can use PC check to see if your system is compatible.
The Radeon 780M needs the VRAM to be set to 8 GB. Normally it is set lower.
