Bring back custom slow motion speed
In previous versions of Video AI we could specify a slow motion rate by typing it in the drop down list, can we get that feature back please? For example: in previous versions we could specify a slow motion rate of 1.2x rather than being tied to the 2x,3x,4x,6, etc…
I’m often looking for a more subtle speed change in some videos I work on. 2x and greater is too obvious and clunky for the nuanced look/feel we were able to achieve in earlier versions of this app.
Please and Thank You!
Hi! This is not something that we removed, you can still type in a custom value :slight_smile:
Great, but this is not obvious in the interface. Popup menus tend not to be editable.
When clicking the dropdown menu, click next to the none and hit delete and then type the speed you want.
frame rate change custom
Once you know it, you’re not likely to forget it.
I understand that it’s not how drop-downs normally work. It would be worse to get rid of the drop-down values though.
Maybe they can restyle it to look more editable, but most of the community would rather their time be spent on more pressing bugs and issues.
