How do I delete images from Bloom? I only can show the reference image and the rendered results, but I can not find any way to get rid of these images and remove them from my account? I don’t want to end up having an endless list of files in my account and I want to delete certain images after processing.
If you go to the home page of Bloom, where it shows the originals next to the rendered results, there is a small checkbox in the top right corner of each image. Selecting that brings up a small toolbar with a button that has a bin icon on it for deletion. That seems to be the only way to delete files.
Thanks, but in no view I see a checkbox in the top right corner of each image – not even if hovering the thumbnail or trying to precisely hovering over certain areas of the images or thumbnails or trying to randomly click the area to possibly trigger some pop-up by chance.
Terrible UI.
I am using Chrome as my webbrowser here. Might that be a problem?
Thank you so much for the screenshot, where I immediately saw, that your page is a different one than all pages I had found (I used the hamburger menu in the upper left of the page and then “My Files” or clicked on “Bloom” there. But while all images are displayed as thumbnails, they don’t have any checkboxes.
I got to the page you show, by just clicking on “Bloom” at the top of the page right to the Hamburger menu. And THERE I now see the checboxes, too (in Safari as well as in Chrome). And I now know, what you meant by “Homepage”.
