I have three monitors, two 10-bit (same type) and one 8-bit. When I run some operations like exporting images, the 10-bit monitors go to a black screen for a few seconds (April 2), but the 8-bit doesn’t. It’s very annoying.
I submitted dxdiag.txt to your Dropbox.
Thanks for sending in that information.
I want to see if updating your GPU driver will resolve the problem, as there is a more up-to-date driver that has been released.
Please use the following link to update your driver: NIVIDA | GeForce RTX 3060 | Driver Update
