Looking for Bioluminescent Glow within Studio. Either Rose or Heath mentioned it as being inside Topaz but I cannot find it. Help!
The Adjustment is called Glow, the most suitable … or you can also use Radiance which will give a different effect.
I saw that one. I will give it a try. Thank you!
Hey,
Sorry for the delay i’m not on the forums that much. THe tutorial was bioluminescent glow, but the effect is using Glow in Studio.
Thanks, Heath!
