It would be very nice to have the ability to apply the same settings to multiple images. It seems that neither DeNoise nor Sharpen have this capability.
Why do you have to be snippy in everything you post? The rules of these fora are to be civil. Maybe try it. Or don’t those rules apply to the moderators?
I can find no way to apply the same settings in batch to multiple images. I can find nothing on the Topaz website that discusses batch application of the same settings to multiple images. The only thing I’ve been able to find is that multiple images can be loaded into e.g., Sharpen, settings are applied to each image individually, then use the Select All function and click Apply. As recent as 3 months ago this article on the Topaz website says nothing about automatically applying the same settings to multiple images, Topaz Labs
In both Sharpen and Denoise if you open a batch of images and check the “Select All” box then whatever settings you choose will be applied to all the images. If you don’t want it applied to them all then just select those to which you do want it applied.
Has this stopped working in later releases? I am using the current Sharpen, and when it begins to process I see it showing different S:xx G:xx values for each image than the ones I set in the manual controls. My preview does the right thing, but it seems Select All is just exporting AI settings and not the ones I chose. Or, the UI is showing that but doing something else?
