Hello, I just got Topaz Photo AI and was excited for the CLI/autopilot features, although they don’t appear to be working as intended.
I have “Remove Noise - Non Raw” set to “Low and above”, the image loads and I can see it’s detected as “Low noise” but the noise model is not loaded. Am I misunderstanding that setting?
The ultimate goal is to denoise photos in my workflow automatically using the CLI, which is hamstrung to the Autopilot settings, but Autopilot doesn’t seem to respect the preferences.
Any help would be appreciated, thanks in advance and for the cool tool!
Thank you for the reply! I did reinstall but I’m seeing the same issue. I attached a screen recording, could you please tell me what I’m doing wrong? I’d like to be able to set some models as “always on”. The way the setting is worded it seems to be possible but it’s not working.
The Upscale filter also does minor denoise and deblur so it looks like because that filter is on, the detection model determined that the specific remove noise filter didn’t also need to be enabled.
Hello,
sadly there is no Always On option yet, I requested the same thing in autopilot preferences.
I have tagged many of my images with a _blurred suffix in the file names and would love to just have the CLI run though all of them. But since there is no way to force it, it doesn’t work.
And even extremely blurred images were never detected, even with low and above. Neither in the UI, nor the CLI autopilot.
I still hope that aways on will be supported in autopilot preferences in the future. Until then I have to use the UI for every single image with manual sharpening…
I would happily pay x10 for a robust, configurable CLI. Strange it hasn’t been implemented yet. So many businesses are trying to cut recurring cloud costs and I’d think they’d jump on this locally run program if it had a better workflow.
That would have avoided lots of broken functionality over the versions in the past (e.g. CLI was completely broken not just once but over 3 times already).
Now at least with the additions of the autopilot prefs I am able to use it half way (by using windows registry entries before starting the CLI, that at least let me set the model, …).
But it’s still to little. Like you also saw (no possibility to force sharpening, no possiblilty to set specific values for the filter and so on).
