The software always chooses the Standard sharpening model, even for photos that have undoubtedly been affected by movement. So I always have to change manually to Movement blur and increase the value of sharpening to get a more or less satisfactory result, My feeling is sharpening used to be much better…
Yes I found that as well. AutoPilot does not work, you need to set it manually and adjust the amount of sharpening. Even then Sharpen AI is better.
