This is mostly for Adjust AI, since the others don’t have the same level of control.
Perhaps this is not possible due to what’s going on under the hood, but I would like to see the “Auto” adjustments reflected in the Control settings. I think it would be both educational to see what adjustments have been applied, and helpful when you want to tweak what “Auto” has done.
