Hi, since applying Topaz’s brilliant AI to standard resolution sources is one of its prime specialties, that of course means there is an abundance of 480 line material out there that has been subject to a 2:3 pulldown.
Although there have been feature requests for Topaz to handle this, I am not sure the features are working properly - they seem to be designed with telecine interlacing in mind rather than my situation which is 480 line progressive that needs a reverse pulldown back to 24 fps before processing with Topaz will work.
So my question is: is there any utility out there still in use these days that can reliably and flawlessly remove the pulldown without the need to transcode the material? In my case, at the present time I run the material through Handbrake to the best possible quality output file that I possibly can. Yes, the losses are small and in many cases you might only tell the difference in a direct A / B comparison, but a loss is a loss on material that is already pretty marginal to begin with compared to modern Full HD, let alone anything better. Furthermore, a slow encode at high quality is time consuming whereas just changing flags would be extremely fast.
The problem is that even after extensive searching,I haven’t found anything that actually works other than re-rendering the material. Anything that used to claim to work doesn’t appear to, has long been abandoned or is so complicated to do it is hardly worth the effort versus the Handbrake method.
So if anyone has a simple near instant process, I would love to hear about it short of simply being able to select an output frame rate of 23.97 fps in Topaz from 29.97 progressive input and Topaz takes out the pulldown automatically (pretty much as Handbrake or Vegas Movie Studio already does). At the moment, Topaz of course does not recognise this possibiilty and instead wishes to enforce interpolation.
