When I select an image from ACDSee Ultimate 2023 to use PhotoAi as an external editor, I do not have the option of adding a suffix or prefix when I save it. It overwrites the original image.
To retain the original image I either have to create a copy manually beforehand or browse to the image in PhotoAi rather than using PhotoAi as an external editor.
Is this a problem you are able to solve or is the issue with ACDSee?
You should always create a copy of the original image before calling Photo AI as a plugin as Photo AI will overwrite all images except RAW files.
