The AI Removal Tool does not work, well partially works. The previous version worked great!
Half the time the program crashes after using Remove
You might be best creating a Support ticket at the main Topaz website. You will need to supply details of your OS and config as well as log files and screenshots. The issue is likely specific to your system and/or configuration.
