Using the update of yesterday, or so) when I bring up an image, and click th reset icon then make a duplicate, the previous adjustments have not been removed
I gather the version you have installed is v1.8.4.
Make sure you click the reset at the bottom of the panel next to the Preset Name, or it may say Custom, rather than the reset at the top pf the AI Remix adjustment because that will reset the AI Remix parameters.
If you have done that it seems as though it is a problem on the Mac as on Windows is fine.
