I’ve installed the trial version of AI Clear. It is making no change to the images whatsoever. When I change a setting, it only takes a fraction of a second to “process” the function, and no changes are made.
I restarted Studio and it didn’t help. I reset the local database and restarted Studio, but that didn’t help. I tried other trial adjustments, and they worked fine.
Firstly how big is the image you are processing, that is in pixel dimensions?
Secondly does your Adjustment look like this, in this case my image is 6000 x 4000 pixels and took ~15 seconds to process. If it doesn’t look like this with the buttons and sliders, exit and restart Topaz Studio:
