Just to let everyone know, if you want to change one of your presets and use the Add preset button and use the same name to overwrite it, the preset doesn’t update properly. The only way is to delete the preset then go back to the controls panel and add the new one using the previous name.
I submitted this to Topaz as a bug and asked them to add a right click to a preset that will update with current settings. We’ll see if it show up in future updates. That should be done to all apps with presets.
