Adjust AI Big Sur Beta?
Is Adjust AI Big Sur in beta? Thanks.
  • Jenny W
    • 5 months ago
Hi Peter,
Thanks for that information. I’m happy to help. We are currently in the process of updating all of our products to function with Big Sur.
Sharpen AI (v2.2.0 or higher), DeNoise AI (v2.3.3 or higher), Gigapixel AI (v5.2.3 or higher), Mask AI (v1.3.6 or higher), and Video Enhance AI (v1.7.1 or higher) have already been updated to accommodate Big Sur (Intel) and Adjust AI, JPEGtoRAW AI, and Studio 2 are in the process of being updated. Some of these updates should occur this week. Others may take several weeks. Most users have also reported that Topaz Studio 2 is working, although there is a false update notification that needs to be corrected. This does not affect the overall functionality of the product itself.
Updates to support Big Sur (M1/Apple Silicon) will likely take several months overall. If your apps won’t open, you can check for new versions within your www.topazlabs.com account or on our Topaz Labs Downloads Page going forward. As a note, legacy programs that were previously discontinued are not scheduled to be updated. Will you let me know if any of the programs listed above that should already be working are having issues?
I will go ahead and put your request on hold, and you will be notified when updates are released. Thanks for your patience,
Jenny W
Support Specialist
Hours: M-F 9am-5:30pm (CST)
Become A Topaz Labs Beta Tester:
http://community.topazlabs.com/g/Photo-Beta-Testers/
  • 5 months ago
Is there an ETA for when Topaz Adjust will work with Big Sur? FYI, Big Sur was release five weeks ago. Thanks.
Jenny W
  • 5 months ago
Hi Peter,
Thanks for your reply. Although we don’t have a specific timeline on that yet, the developers are working on some tests and should know more within a few weeks.
Kind regards,
Jenny W
Support Specialist
  • 4 months ago
Hello,
Is there an ETA for Big Sur Adjust AI? It’s been two months…
Thanks,
Pete
  • 4 months ago
Hi Peter. Our developers just notified us they are targeting the end of February for updates to Adjust AI and Jpeg to Raw for Big Sur. Studio 2 should be before that if applicable to you.
Thank you,
Eric Lowery
Operations Manager
M-F: 9:00am-5:30pm CST
  • 1 month ago
Please provide a hard date when Adjust AI and JpegToRaw will function on Bug Sur. Before responding please read thread. ThankYou!!
Peter,
Unfortunately, I don’t have a hard date I can provide you at this time. We will release it as soon as we are able. We are already past our original target release date and working to resolve several unexpected conflicts that have delayed the release. It will be released as soon as it’s stable and tested. This will likely take several more weeks due to the broader testing that will be needed once primary development is complete.
As a side note, this update consists of some significant changes that aren’t specific to Big Sur to bring the app current with our other apps, so the delay is not just for Big Sur compatibility. The entire app has to be retested for stability, not just Big Sur compatibility.
Regretfully,
Eric Lowery
Operations Manager
