Although recovering faces do a really great job to varying degrees dependent on the original I’d like to be able to add some gaussian noise after processing using a negative noise value rather than scaling back the recover faces effect… there is a difference and I’d like to add some fine granularity to keep the faces alive. I realise this can be done of course in post in Photoshop.
Thanks for the idea and suggestion! Make sure that you do not forget to vote for your idea
