Add noise vs. grain - what's the difference?
Hello.
Video AI v3.1.9
M1 Mac Ultra
macOS 12.6.3
I have not found an answer yet, is there a specific use for the “add noise” option? Adding colour noise seems odd in the enhancement process - usually, we try to remove it. Adding grain after processing I understand to mimic film look and smooth gradients. So, what’s the difference for “adding noise”? At least with lower bitrates, it creates awful compression artefacts :slight_smile:
@Imo Do you really feel (based on your experience) that adding noise before processing really enhance the video quality after it’s fully processed?
if so, what settings of add noise do you usually use?
what value you usually use?
me according to my experience, by adding 1 or 2 max, it can remove some artifacts but the more you add, the more it removes details, and the image becomes less clear.
About grain, how much do you add?
