Ability to KeyFrame on timeline
I would love to have keyframing on the timeline. Key-framing different “set ups” or parameters with a video clip (using timeline). Some setups work great for parts of a video but not for other areas. Key-framing parameter changes at certain timecodes on the timeline and/or scene cut points would allow several modifications on a timeline offering superior end results.
Also the ability to add notes to the previews for better ability to find the best setups for a clip when multiple have been used!
-Scott
Moved this suggestion to the ideas section, don’t forget to ‘Vote’.
Although we do not have keyframing functionality built into the app at this time, you can use keyframes through invoking the plugins in After Effects and DaVinci Resolve Studio.
hi. I’ve just read this post. I’ve imported a video clip into AfterEffects but the topaz plugin appears to have no keyframe option
If the goal is to keyframe the effect in and out as you need it for parts of the videos and not for others, I would recommend pre-comping the layer and keyframing the opacity
