What codecs does Video AI use for 16K that can be opened in Premiere Pro? Im aware that MP4 H265 is only good up to 8K and can’t go above that with your software. Im using version 4.09.
Not sure that TVAI has any official support for 16K output in its encoding. Maybe try FFV1. Otherwise, you might be stuck with just using image sequence output.
The only codec already built into the program that supports 16K resolution is ProRes. Otherwise, you can add your own codecs.
Isn’t AV1 supposed to handle such excess of resolution?
