[1.0.4] Topaz does not render video with selected resolution
Steps to Reproduce:
  • Load a video and select an enhancement preset that includes upscaling
  • Change the target resolution for the upscale
  • Enqueue the render
  • You will see in the encode queue that it is rendering with the target resolution from the preset instead of the modified one.
Expected Behavior:
The video should render at the resolution I entered.
Workaround:
Cancel the incorrect render and then enqueue a new one, the second one will target the correct resolution.
Looking into this and testing but have not been able to recreate this at this time. Will also have the QA team look into to see if they can replicate.
What presets were you using?
I had this occur with two custom presets. I will provide more info if I am able to replicate it again.
I wonder if it is related to using the Batch Export button—even if I am only exporting one video, I use this button because it avoids an extra popup where I have to specify the output directory, so it is more convenient.
