The original image file.
The processed image.
A screenshot or description of the settings panel so I can see what adjustments were turned on.
Thanks for the reply. I sent the original NEF image as well as the Processed DNG file. I don’t know exactly what settings I used but the enhancements were DeNoise, Face Recovery and Sharpening. The first 2 were what the AI model chose and I added the sharpening. The color shift happened before I applied the sharpening. The ISO was 20,000 if that helps.
Other than the color shift, the images looked great.
I was able to replicate this color shift you are reporting on my machine and have reached out to some of the developers and will be sure to let you know once I have more information regarding this issue.
A current workaround you could try using is processing this image with the External Editor plugin which is accessed through the following path Photo > Edit In > Topaz Photo AI
Hello,
I’m using Lightroom classic with Topaz AI as extras. I processed the picture from Lightroom to work in Topaz, when I export in Lightroom the new picture appears correct but when I paste the masks done in the original picture, I get a picture with colors changed !
Best regards
Guy
Hello,
I extract the dng file with Topaz from the original folder. I let work the automatic process of Topaz. Next I export in Lightroom classic (version 13.4, camera raw 16.4). When I put on this new file (Z08_5066-Topaz-Denoise-Sharpen.dng) the masks worked in Lightroom, the colors are changed.
It’s exactly the same result using: File > Plug-in Extras > Process with Topaz Photo AI.
You will find below different attached files to understand the trouble:
screenshot of the original dng file in LR
-screenshot of the Topaz window after automatic noise-sharpen process (colors are already changed)
screenshot of the exported Topaz file in LR (colors are correct !)
screenshot of the exported Topaz file with LR masks
You can observe that the result is fully different when we compared the LR file with masks and the Topaz file with masks !
It was not the case with the previous version.
Best regards
Guy
@john.topazlabs I’m having the same color shift issue applying RAW denoise to Z8 NEF files, including in Photo AI version 3.1.0.
The workaround you suggested (Photo > Edit In > Topaz Photo AI) avoids the color shift bug, but my vague understanding of the description of RAW denoise is that it has advantages over the generic denoise enhancement.
Can you share more information about the benefits of RAW denoise over the generic denoise and differences in how the two enhancements work? That would help me determine if I want to wait to process some photos until the color shift bug is fixed. Also, do you have an estimate of when the bug will be fixed?
The RAW Denoise enhancement specifically processes RAW images using a proprietary demosaicing algorithm. This algorithm converts sensor data to pixel information, retaining more image data and details than pixels. Instead of estimating missing color information for each pixel based on neighbouring pixels, the AI model uses context from the entire image and compensates for noise that hinders traditional demosaicing methods. RAW Denoise typically provides superior noise reduction and detail preservation for RAW files.
The generic Denoise filter eliminates distracting noise cause by low-light conditions or file compression while recovering crisp details. It can be applied to various image formats such as JPEG, TIFF, and PNG. While effective it does not leverage specific advantages of RAW data, such as the roader color depth and dynamic range available in RAW files.
Regarding the color shift bug you are experiencing while using the Z8 files our team is actively working on resolving this issue, but I do not have an exact timeline for when the fix will be available. I can assure you that this is high priority for our developers to resolve.
Hello,
I sent you some files as you requested via dropbox on the 13 th of July. Since I have no answer regarding the trouble of colors.
Best regards.
Guy
Our developers and team are working on resolving this color shift problem with the Nikon Z8 camera model. As stated above, I do not personally have an exact timeframe as to when the fix will be available; however, I can assure you that this is a high priority for our developers to resolve with future updates.
Get this out of the way…I realize I can process TIFF files instead of Raw. That’s a poor work around professionally. All I want to do is denoise and sharpen.
Issues when moving RAW files from Lightroom to Photo AI:
Color shifts - It seems to affect blues the most.
Histogram shifts - Histograms shift to the left roughly 1 stop to the left, under exposed. They also shorten and widen. The Basic panel adjustments (the numbers and slider positions) are the same on the DNG file when it returns as on the Raw file that was shipped over, but the image needs to have Basic panel re-adjustments when it returns from Photo AI after just sharpening and denoise.
Crop adjustment not kept - Files transfer in from Lightroom with the crop adjustment intact, but after denoise and sharpening the crop is dropped when the DNG transfers back to Lightroom. I have to re-crop the file or copy and paste development settings from the Raw file to the Topaz generated DNG file.
Multiple files open - Occasionally, if I had to put a number on it I’d say once every 25-30 times, when I transfer a file to Photo AI it opens fine. Then after a moment or two other files open as well. When I close Photo AI it will re-open by itself and open those same photos. If I close Photo AI again it stays closed and when I transfer the file again only it opens.
Hangs - When transferring a DNG file back to Lightroom after denoise and sharpening, occasionally Photo AI will hang while processing. I’ve left it for 20 minutes to see what happens and it still is hung and I have to force quit the application on the MacBook.
Crashes - this is similar to hangs, When transferring a DNG file back to Lightroom after denoise and sharpening, occasionally Photo AI will crash.
Steps to reproduce issue:
Make Basic panel and crop adjustments to a Raw file in Lightroom.
Transfer the file to Photo AI by selecting File → Plug-in Extras → Process with Topaz Photo AI.
Use Denoise and Sharpen subject on the file in Photo AI.
Return the post processed DNG file to Lightroom in a stack.
Sorry, John. The Photo AI processed file is 161 MB and exceeds the file size limit set by Topaz from the thread. I’ll upload the files to your DropBox.
