XPS 8960 vs Mac Mini running Topaz Video AI
Hello everyone, I’m looking to buy a PC to run Topaz Video AI. I’m in doubt between a Dell XPS with an i7 14700 + 32GB RAM + GTX 4060 or a Mac Mini M4 with 24GB RAM. Does anyone have any idea where the performance would be better? Thanks in advance.
Hi, Comparing the benchmarks on here, a standard 4060 is faster than a Mac mini with M4 Pro in every test, and much faster for Iris. In general, unless you’re already a Mac user or particularly want a Mac for other reasons, I would discourage everyone from getting a new Mac for TVAI. They aren’t the best combination in terms of price and performance.
Regards
Andy
If you would like to take a look at the benchmark results from other users that Andy referenced you can go to the benchmark page and that might help with your decision.
Benchmark results
Below is a copy and paste of two benchmarks to compare.
You might want to consider the possibility of buying 2 x base M4 Mac minis, given how small they are, and that a TVAI licence allows you to run on two machines at the same time. That would actually work out cheaper than the Dell XPS with 4060 and mostly better overall performance than the Dell. I thought it only fair to point that out for completeness.
Topaz Video AI v5.4.0
System Information
OS: Mac v15.01
CPU: Apple M4 16 GB
GPU: Apple M4 10.667 GB
Processing Settings
Input Resolution: 1920x1080
Benchmark Results
Artemis 1X: 07.19 fps 2X: 04.40 fps 4X: 01.50 fps
Iris 1X: 05.23 fps 2X: 02.97 fps 4X: 00.80 fps
Proteus 1X: 07.41 fps 2X: 04.98 fps 4X: 01.33 fps
Gaia 1X: 02.29 fps 2X: 01.74 fps 4X: 01.20 fps
Nyx 1X: 01.30 fps 2X: 00.95 fps
Nyx Fast 1X: 04.37 fps
Rhea 4X: 00.27 fps
4X Slowmo Apollo: 08.13 fps APFast: 09.69 fps Chronos: 02.48 fps CHFast: 03.98 fps
16X Slowmo Aion: 05.13 fps
Topaz Video AI v5.5.1
System Information
OS: Windows v11.23
CPU: 12th Gen Intel(R) Core™ i5-12500 63.745 GB
GPU: NVIDIA GeForce RTX 4060 7.7705 GB
Processing Settings
device: 0 vram: 0.9 instances: 1
Benchmark Results
Artemis 1X: 10.06 fps 2X: 07.30 fps 4X: 02.35 fps
Iris 1X: 10.83 fps 2X: 06.30 fps 4X: 01.75 fps
Proteus 1X: 10.23 fps 2X: 07.22 fps 4X: 02.39 fps
Gaia 1X: 03.42 fps 2X: 02.30 fps 4X: 01.56 fps
Nyx 1X: 04.13 fps 2X: 03.55 fps
Nyx Fast 1X: 07.53 fps
Rhea 4X: 01.37 fps
4X Slowmo Apollo: 15.39 fps APFast: 40.87 fps Chronos: 08.24 fps CHFast: 12.61 fps
16X Slowmo Aion: ERR fps
Thanks Andy, I’m a newbie using a MacBook Air M1 for TVAI.
I live in Brazil and here the prices of the machines I mentioned are similar. So I’ll buy the Dell for TVAI and virtual machines too.
Grettings
Raimundo
