Wrong Window Snapping Behavior
(DISCLAIMER: I have a three monitor setup with different resolutions)
  • The maximize/restore button isn’t always consistent or correct. When starting from maximized state then dragging down the window to un-maximize, the maximize button requires two clicks before it maximizes again.
  • Maximize/restore does not have the normal ease-in animation.
  • Window does not respect Snap feature in most cases. Window cannot be dragged to the edges of the screen to maximize or snap to a side/corner. Also does not support Windows 11’s Snap Layouts feature.
  • Window snap/move shortcuts not fully working. WIN+Up does not maximize, but the other arrow key shortcuts do work as intended. WIN+Z does not open Snap Assist. WIN+Shift+Arrow Keys mostly works as intended; When the window is maximized and WIN+Shift+Left/Right Arrow is used, the window will move to the other monitor but it fills the entire screen and covers the taskbar.
There’s a Microsoft Learn page called “Support snap layouts for desktop apps on Windows 11” which addresses most of these issues I think.
  1. Your system profile
    DxDiag.txt (153.5 KB)
  2. Your log files (Help > Logging > Get Logs for Support)
    logsForSupport.tar.gz (193.7 KB)
  3. Any screenshots as necessary
Thank you for sharing :slight_smile:
Would you mind sharing a screen recording illustrating how this creates friction for your workflow?
Oftentimes it is easiest to share a screen recording for issues like this to quickly show me exactly what is happening. I use Loom for screen recordings since this is a free and easy to use app.
2023-08-03 22-57-49.zip (31.9 MB)
It wouldn’t let me upload the video directly so I’ve put it in a zip file. I hope this shows it well enough.
EDIT: I forgot to show dragging the window into the screen corners which also doesn’t snap properly.
This is great! Thank you! These are all issues we are looking into.
