I like to remember what I’ve done to a photo when using the AI products with Lightroom, I try to edit the filename when it returns from Denoise, or Sharpen or Gigapixel and the others. There’s got to be a better way. If I use Denoise, I should have a way to retrieve what settings I used. If I then use Sharpen AI, the settings I used should be added, and so on.
If I use the stand-alone option, the filenames are modified, but not all settings are in the filename.
Can you embed this info into the image metadata, and provide a way to read it back out?
