As it appears that you recommend that Denoise be performed before Sharpening, why not provide an option for Denoise to ‘always’ be run before sharpening, even if you added it after a run with sharpening. Of course, as an option, you could turn this off if you want the order to be different. But because this is your preferred order, having an option to set the order before working on a photo might just facilitate the process a bit.
Thank you.
I tried to get them to fix this for months, since the v3 (or 3.2 I don’t remember) came out, the day they fixed the upscale module to be processed at the end.
original + 4x
original + sharpening (imagine sharpening an image at its lowest resolution) + 4x
exported 4x upscale, imported again then sharpening
It’s the same thing with everything else, like noise reduction, etc…
