Work flow with Resolve
I just purchased Topaz AI4. I also use Resolve v18 to edit and color correct. what basic workflow should I use ?
Import , Edit, Color, export, / Import to Topaz, process, exoprt
Could a rearrangement possible improve the results? My project is currently Restoring old 8mm family films.
Thanks
Rick
I would recommend sending the clips you need to enhance to Video AI after you do a rough cut in Resolve. This way you can bring it back into Resolve after the AI enhancement and then do your color and any effects needed. Sometimes AI models can cause a color shift and you do not want to have to color twice.
Agree totally, always last step to fine adjust in Resolve.
