This image was cropped and then run through A.I. Gigapixel at 200%; then taken into Studio where the following were applied: A.I. Clear, Precision Contrast, Precision Detail; Adjust 5, Adaptive Exposure; Just Right preset (lowered opacity). Some final touches were done in ACR.
Beautiful capture! Very nice processing, too. But there are some really strong chromatic abberatuins, for example the purple at the border of the rock to the left. You should be able to decrease them depending on the softwate you use
Thanks, Ken. I was aware of that. If I decide to print it, I will fix those.
PS, Ken - I think that I fixed the purple fringing. I printed it and it’s not perfect, but it doesn’t look bad from a “normal” viewing distance.
