Will Not Start Export
    The software refuses to start processing, with just an error reported.
  2. Your system profile
    Windows 11, AMD 5950X, 16-core/32-thread, 128GB RAM
    Attached
logsForSupport.zip (2.9 MB)
Open the Preferences Panel and let’s change the following settings.
File>Preferences>Processing
  1. Ensure that your GPU is selected for the AI Processor - RTX 4070
  2. Set the max memory to 80%
  3. Set max processes to 1
  4. Save the settings and close the panel.
  5. Re-run your clip through the process that you were trying.
If you run into an issue again, please send me the updated logs for further review.
help@topazlabs.com
