Why so slow
Gigapxel is so slow now what has happen to it, is there a way to make it faster??
Bill
You can change the AI Processor settings to designate the strongest piece of hardware for processing. You can do so by following the steps below.
  1. Open Gigapixel as a standalone.
  2. Go to Edit > Preferences.
  3. In the General section of the Preferences window, change the AI Processor to your preferred piece of hardware.
If this still doesn’t help, let me know. Also, make sure your machine meets the system requirements for Gigapixel.
Thanks that helped alot
Bill
Hi @william.donnelly , can you help send us the log files. You experience might indicate there is a bug in our app. Thank you!
Open Product → Help → Open Log Folder, and zip the send us the files there. Thank you again!
