Why is there Window 1 and Window 2 now?
Sorry for the question, but I am confused by this. Before you had your original video shown. Then you would apply a setting. After that you can always compare the original and the newly rendered version by split screen, etc.
I do not understand #1 and #2. How can I just have it show one window that I can scroll back and forth between the original and the rendered version?
It seems so complex now. Perhaps I am just getting old. I find myself taking more time to setup videos to render than before.
Am I missing a setting?
The point of 1 and 2 is to apply different settings and compare them between the two so you can select the best settings. When you export there is no longer a live preview.
Hence the two window thing.
With the lack of Mac speed improvements, no live preview - there are much better alternatives.
I get random crashes now too.
AI is being incorporated into Adobe products — so I think this will not be able to compete soon on the Mac side.
But then Adobes solution is server side with all benefits and downsides.
Topaz’ AI fully works only on your computer, so no privacy issues.
And how is that a selling point for people with older or less powerful devices that don’t want to spend thousands of dollars getting new equipment, in the hopes that one program “might” work?
It’s not - and I never said that. Just that it’s a different approach with advantages and disadvantages.
Not every one feels comfortable (or is even allowed to) load up personal images / videos on a third companys server.
Besides the local approach is more flexible - options like output as a series of PNGs or low to uncompressed 4k video isn’t really feasible with an online approach even considering todays internet speeds.
Privacy issues are long gone now.
Care to elaborate?
I tested TVAI and another video AI program on a cloud-based virtual desktop a few months ago. The reason was that my main machine is 100% Linux and I prefer to do as much as I can from that device.
The cloud desktop worked fine, only problem was that I wanted to change some system settings and the company did not allow users to adjust the settings. And, like you said, they slipped some language into the ToS about having the right to look at what you’re doing.
But the future of all mainstream app development seems to be to include at least some server connectivity. Heck, even TVAI checks your license through a licensing server each time you launch the program instead of using offline licenses. And you have to manually download the models if you want to keep them on your device.
And there’s also the fact that Topaz collects anonymous usage statistics by default and you have to manually turn this off.
I’m in total agreement with you. With Adobe, there is no privacy period with any of their AI products. With Topaz, you don’t really have to worry about it since all processing is performed locally.
I agree with @michaelpfost, I don’t believe Topaz would be able to compete under their current trajectory. ‘Better privacy’ is not a strong argument against ‘better stability, performance, and UI/UX’, especially now that more established companies are getting into AI.
But Topaz seems to understand this, and they’ve already begun integrating into other products, for example with the release of the Ae plugin.
That’s really no explanation.
Of course the needed models have to be downloaded, otherwise TVAI would be a 16GB+ download for each version. And those are Topaz’ data/code that you are downloading, not the other way round.
Besides, if those models are there, they don’t need to be downloaded again - fortunately as otherwise I could not exchange the current extremely slow Iris model files with faster ones I extracted from past installations (a BIG thanks to TimeMachine here).
So the internet connection is really only needed for activation - the actual encode is fully local: I’ve done quite a few encodes with capped internet earlier as I feared TVAI would replace my faster old models with new ones and thus took the rig from the net - until I noticed that it doesn’t do that if it finds an appropriate model.
And last, not least: I’m not talking about “some server connectivity” or anonymous usage data but about uploading your private images and/or videos in total to a foreign server that often is located in countries with dubious user rights.
Also, it doesn’t even matter if you would accept that as in quite some cases with professional work you just aren’t allowed to upload images of your customers (at least not without getting explicit permission by them to do so). Maybe in the US this doesn’t matter but with the european GDR you can have a big problem here.
Of course, the online approach of e.g. Adobe has it’s advantages for both the user (that doesn’t need a strong computer and still gets faster results) as well as the developper (who has an exactly defined setup and thus doesn’t have to take care of those many many different configurations with different driver releases, making software development MUCH easier
It’s not a matter of better privacy, it’s a matter of zero privacy with the cloud based solutions.
I would wager a good percentage of the VAI users are enhancing copyrighted material such as older movies and TV shows.
Nothing would stop a cloud based solution from saying, sorry, we don’t allow copyrighted content - you’re out of luck.
The same could be said about Google Drive, One Drive, and so on. It doesn’t stop anyone from uploading copyrighted material to their servers. Even YouTube lets users store copyrighted content on their servers, it just restricts viewership based on location.
