I’m trying to upsize an image that I don’t want any noise reduction applied to. Even though the NR is not turned on, it’s obviously
being applied. I simply want to resize with no NR. Why is it applying NR?
Some models tend to apply a minor noise reduction themself as a side effect of their own modification.
Make sure you disable Face Enhancement on the monkey
It seems that Face Enhancement is enabled and blurring the face
Additionally, I recommend using the Standard AI model or the High Fidelity AI model, as the Low Resolution AI model tends to remove fine details.
Very good. Thanks.
Best wishes, Dan
Daniel J. Cox
Natural Exposures, Inc. Home Page
Instagram
Blog/Corkboard
Facebook
Natural Exposures TV
LinkedIn
Pinterest
Please consider the environment before printing this email~
The upscale model does minor deblur and denoise. I’ll talk with our developers to see if we can have a setting where it doesn’t do that and only upscales.
