Hi everyone, I am on build 4.0.7. I want to enhance a 1080p video, but the quality of the image is pretty bad. Can anyone suggest what model I should use?
I’m a bit lost with this.
Cheers
Cheers
sample of the video would be helpful
Sounds like the Fix Focus feature might help.
Without a sample video, all I suggest is Proteus 4 Manual. Leave everything at zero—Including Recover Details. Between making previews, increase the Fix Compression slider by 10 until it looks better. Then do the same with Sharpen. You can put Improve Details up to 12 if you want.
If Sharpen makes unwanted patterns in things like grass, trees of gravel, put it back to 0 and start putting the Anti-Alias/Deblur up by 5 points.
Where can I upload a sample video? I downloaded openshot so I can edit the video.
If you make it less than 50MB, zip it and drag and drop it here (this forum).
